9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Revit 2024: Toposolids clash with walls/foundations...
26 Posts No Rating |
Hi all,
Having upgraded to Revit 2024, the most pertinent difference / upgrade is that Toposurfaces have been replaced with Toposolids; works much better actually! But in Section my walls & foundations are masked by the toposolid. Merging them doesn't work, neither does "cutting" the walls/foundations into the toposolid.
Has anyone experienced this, and perhaps found a solution? The Autodesk website states that one should "cut" the elements into the toposurface, but in practice it hides the elements behind the toposurface pattern, or suddenly joins the wall-base to the bottom of the toposolid...
See image attached.
Thanks in advance!
I know this is an old post, but did you ever find a solution for this problem? I just went from version 2023 to 2025 and I see
the same problem. Thanks
revit 2019 and revit 2024 same pc |
Tue, Sep 19, 2023 at 7:54:31 AM
Brick Corbelled Foundations |
Mon, Aug 9, 2010 at 8:46:12 AM
Clash Detection |
Fri, Oct 23, 2009 at 1:45:07 AM
Clash Detection |
Mon, Jun 2, 2008 at 7:17:53 AM
Clash Testing in ONLY Revit |
Wed, Jan 7, 2015 at 1:03:04 PM
