Forums >> Revit Building >> Technical Support >> Painted surface
Sun, Jun 18, 2006 at 11:17:17 PM | Painted surface
puzzle
4 Stars: 10 Votes
Is it possible to find out what material has been used to paint an object?
Macca
Sunshine Coast
QLD Australia
Thu, Aug 30, 2007 at 12:30:11 PM | Painted surface
charlotte240
charlotte240 Avatar
3.5 Stars: 3 Votes
Go to "settings"  then "options"  Go to the "General" tab.  Make sure you have enabled "tooltips assistance" to anything except "None"  <P>   very important<P>Then go to paint bucket tool or split face tool, then hover over the resgion you have split, in a reasonable view. Crying(if you drew a facade elevation with painted surfaces, go there to inquire)) The area you split highlights, it will bring up a tooltip listing what the surface is, and if the paint command was used, it will indicate the original surface material, as well as the painted surface material.<P>I wanted to post you a screenshot, but I can't get the screenshot to include the pop-up tooltip!   sorry!
CRI
Thu, Aug 30, 2007 at 12:31:01 PM | Painted surface
charlotte240
charlotte240 Avatar
3.5 Stars: 3 Votes
CRI
Align painted surface
Fri, Jul 22, 2016 at 1:28:22 PM
painted split face doesn't show in dependent view
Mon, Nov 1, 2010 at 12:32:13 PM
Floor pattern showing through objects
Tue, Apr 1, 2014 at 7:52:43 AM
How to take quantities from painted surfaces?
Tue, Oct 10, 2017 at 1:00:43 AM
painted cmu wall..
Thu, Nov 14, 2013 at 11:16:49 AM
Page generation time: 0.2421
