Forums >> Revit Building >> Technical Support >> 3d levels new to revit !
Mon, Sep 13, 2004 at 3:06:09 AM | 3d levels new to revit !
spot
Help new to revit. How can I turn of levels so in 3d so I can see individual levels or is it not possible? Thanks.
Mon, Sep 13, 2004 at 2:48:26 PM | RE: 3d levels new to revit !
PScottHull
I don't believe that you can turn off levels (I may be wrong though), but what you can do is check the "Section Box" selection under the view properties, which will allow you to manipulate what portion of the model is shown in the 3D view...you can modify both vertically and horizontally.
Wed, Sep 15, 2004 at 4:36:55 AM | RE: 3d levels new to revit !
spot
Thanks Scott section box seems to work o.k, surprised there is no switch for viewing levels,I'm use to working in layers where this feature is common.
Wed, Sep 15, 2004 at 10:02:13 AM | RE: 3d levels new to revit !
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
You could place all elements on each level in separate worksets and turn off those worksets in your 3d view...
Hiroshi Jacobs
The Catholic University of America
Cannot see my floor levels
Tue, Mar 10, 2015 at 12:42:26 PM
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
Page generation time: 1.3944
