Forums >> Revit Building >> Technical Support >> Adding thickness to topo surface???
Thu, May 11, 2023 at 11:57:53 AM | Adding thickness to topo surface???
cgullett77
Is there a way to add thickness to the topo in a model created in Revit architecture?   I'd like to be abe revolve the model without seeing basement walls etc. which are below the surface.
Thanks!
Fri, May 12, 2023 at 10:49:55 AM | Adding thickness to topo surface???
I wrote this up in 2013: Make sure your topography extends beyond what you want to show, then create a section box inside of that and to the limits of what you want.  Now, turn the section box on in your 3d view.
Topo Cut Line thickness
Tue, Feb 14, 2012 at 10:49:24 AM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:58 PM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:25 PM
placing a street, vegetation and barrier or railing on topo surface
Tue, Jan 17, 2017 at 5:47:40 AM
Page generation time: 1.6535
