Forums >> Revit Structure >> Tips & Tricks >> Showing Horizontal Lap Siding correctly in Rendering
Mon, Jan 23, 2023 at 10:04:49 AM | Showing Horizontal Lap Siding correctly in Rendering
dhollyman1
Good monring.
I'm currently designing a home that will have (4) different types of Siding.
Horizontal siding seems easy but I'm have a tough time getting it to show coorectly with definition. Anybody have a trick or great Bump. I would like to use a bump so that I can add custom color.
Thank you for your help.
Mon, Jan 23, 2023 at 2:41:29 PM | Showing Horizontal Lap Siding correctly in Rendering
Bump has nothing to do with color, it defines the 3D look of the material.  These materials are not physically 3d, the bump creates the illusion and that keeps the file size manageble.
You can set the color with any well made material.
Sat, Sep 27, 2025 at 9:38:10 AM | Showing Horizontal Lap Siding correctly in Rendering
Hinface1986
honestly siding in renderings is always tricky, cause bump never really looks like real overlap, just fake shadows. sometimes I cheat and use a really good seamless texture with both bump + slight displacement, then tweak color overlay so it feels custom. the deep thought here? render is just suggestion, not reality, you only need it to “read” like siding, not actually build every plank in 3d. kinda freeing once you accept that illusion is enough.
rendering horizontal wood siding.
Wed, Aug 5, 2009 at 10:49:00 AM
lap siding to show in rendereings???
Fri, Jun 26, 2009 at 8:53:55 AM
Lap siding hatch not showing on one wall
Thu, Nov 29, 2007 at 9:01:43 AM
revit 2015-exterior elevations horizontal lines of wood siding
Sun, Dec 6, 2015 at 10:01:16 PM
Multiple width lap siding.....
Thu, Jun 6, 2019 at 8:31:11 AM
Page generation time: 4.2654
