13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Remove the number of back up files in revit 2023
Hello,
I have been using Revit 2023 architectural template and the backup files are too many. How do I reduce them, ot jsut 4 maximum?
Thanks in advance
To change the number of backup files generated by Revit 2023, you can adjust the Maximum Number of Backups option in the File Save Options dialog box. Here's how to do it:
open the project file - "Options" - "File".
(on the File tab, in the File Save section, you will see the option "Maximum number of backups")
The default value is 20.
Change the "Maximum number of backups" value to 4 or whatever number you want.
Click "OK" to save your changes.
Revit will now create a maximum of 4 backup files per project.
Edited on: Sat, Jul 27, 2024 at 7:38:19 AM
Revit 2023 Un-Lock a Viewport |
Tue, Dec 6, 2022 at 8:47:30 AM
Revit 2023 - Can't Link Revit Models From Autodesk Construction Cloud |
Fri, May 5, 2023 at 12:09:54 PM
Revit 2023 Crashes Every 5 minutes or less |
Tue, Dec 26, 2023 at 1:36:12 PM
Viewport Title - remove circled number? |
Wed, Sep 24, 2014 at 8:54:36 AM
BACK UP FILES WITH WORK SHARING |
Wed, Apr 28, 2010 at 10:05:09 AM
