Forums >> Revit Building >> Technical Support >> Graphic overrides by phase
Fri, Dec 16, 2022 at 7:18:16 PM | Graphic overrides by phase
emorrow2030
Hello!
I'm trying to use graphic over rides by phase to differentiate new walls from existing walls.  I'm trying to make the cut section of the existing wall dark gray and light gray for new walls.  This is for presentation only and will revert back to a different visual scheme for CD's. My existing walls are showing up dark gray. Perfect.  But the new walla are not turning to light gray?!?  They stay white despite the override.  I've assigned the correct phase to each wall in the properties dialog box.  Any idea why phase override is not effecting the new walls?  Thanks in advance!
Mon, Dec 19, 2022 at 8:11:37 AM | Graphic overrides by phase
marmiketin1
4.5 Stars: 10 Votes
Are you using a filter for the existing walls? Do the same thing for the new walls using phase created --> new construction and then set the override for the cut pattern.
Phase Graphic Overrides
Wed, Jul 10, 2019 at 4:01:45 PM
Dual Phase Graphic Override?
Tue, Apr 28, 2009 at 9:23:26 AM
conflicting graphic overrides...
Fri, Oct 12, 2012 at 10:44:04 AM
Phase Graphic Overrides Not Working!! (very frustrated)
Fri, Aug 7, 2009 at 9:41:12 AM
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
Page generation time: 0.6719
