Forums >> Revit Building >> Technical Support >> Export Layer Table
Thu, Jun 15, 2006 at 9:25:21 AM | Export Layer Table
I am unable to load a Revit to ACAD export table in Revit 9. I started with the Revit AIA std which I pulled into Excel so I could sort and modify it. I resorted it to the original order prior to saving as a tab deliminated text file. Both the original txt file and my file appear to be the same but when I load mine, the category names are relisted in the layer name columns and no color numbers are listed. Any ideas or experiences????
Thu, Jun 15, 2006 at 1:04:04 PM | RE: Export Layer Table
I've worked around the problem ... still don't know what was wrong. However, I have identified a problem that Revit doesn't expose in their help pages. It appears that they will only accept 0-9 color numbers. Colo numbers larger than 9 are parsed and only the first digit is used. I can work around that my having a correct base sheet setup and then importing the eport file into it.... kind of kinky.
Layer names
Mon, Aug 15, 2005 at 9:15:07 PM
Export Setting
Tue, Dec 6, 2005 at 3:44:44 AM
' Finish[4] ' Export settings
Thu, Feb 16, 2006 at 6:48:51 AM
How to export CAD with custom subcategory layer
Tue, Feb 15, 2011 at 10:08:37 AM
EXPOR LAYERS for WALL HATCHES are missing
Tue, Feb 28, 2006 at 7:51:15 PM
Page generation time: 2.9774
