Forums >> Revit Building >> Technical Support >> Spiral Stair: Railing slanting malfunction?
Mon, Oct 3, 2022 at 10:03:20 AM | Spiral Stair: Railing slanting malfunction?
Fryingpanman
Hi,
Revit Architecture Ver. 2022. I've created a spiral stair, with a vertical profile for the railing (it'll be a continuous timber "upstand" as per the first image attached below). I attached a second image (screenshot) of the profile I've created. The last image (screenshot) shows hows the railing-top sits correctly, but the bottom is bent / slanted inwards toward the stairs-clashing with the stairs. All settings (offset, etc.) are correct - no slants specified.
Any ideas what may cause this?
Cheers!
Residential Spiral Stair
Mon, Feb 16, 2015 at 10:02:06 AM
Stair with Spiral Wall raling
Fri, Sep 28, 2007 at 12:47:22 PM
Railings for spiral stair is not following stair incline
Mon, May 20, 2019 at 8:36:25 PM
stair and ramp railing
Sat, Sep 9, 2006 at 3:41:33 PM
spiral stair needed, please.
Thu, Jul 5, 2007 at 5:38:38 PM
Page generation time: 2.1901
