Forums >> Revit Structure >> Technical Support >> Reference to nested family
Wed, Sep 21, 2022 at 4:18:22 AM | Reference to nested family
Mati945
Hello,
I neet to make a parametric steel frame family. The problem that I have with that is when I try to reference thickness of my colum (nested family) to my reference plane with properties it doesn't work.
Wed, Sep 21, 2022 at 7:49:43 AM | Reference to nested family
marmiketin1
4.5 Stars: 10 Votes
The column thickness needs to be a parameter in the nested family (either type or instance) then you need to associate that parameter (little grey button to right side of parameter in properties) with a parameter in the host family. Then you can reference it using other parameters or in formulas in the host family.
Nested family always vertical?
Mon, May 16, 2011 at 2:55:02 PM
Nested Family referencing Host family
Fri, May 10, 2013 at 7:15:14 AM
nested family rotation
Tue, Sep 3, 2013 at 1:25:41 PM
Family 'Defines Origin' with nested families not working
Mon, Oct 10, 2016 at 3:36:23 AM
Trouble with Array Parameter within a nested family
Wed, Sep 12, 2012 at 5:19:16 AM
Page generation time: 2.1128
