21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Rotating Views on a Sheet
How do I rotate a floor plan on a Sheet so make it line up with the matching elevation?
8 Posts No Rating |
There are two ways to approach this problem:
1. In the sheet view, you can right click on the view and scroll down to select "Activate View" option.
Make sure that the crop region is on. If is is not on, you can right click and go to "View Properties"
and check on the box for crop region. If the crop region is on, you need to click on the crop region
box to select the view. Then, you go to "Rotate" and rotate the view. After everything is done, you
can turn of the crop region. Now, you can right click to select "Deselect View " option to go back to
the sheet.
2. In the working plan view, you can click on the crop region box to select the region boundaries.
Then, you go to "Rotate" to rotate that particular view. You can perform this step after or before
you put your plan view on the title block.
Ok. THanks very much.
What if I have a piece of custom furniture in a plan for an apt that I want to hone in on to show more details in plan & elevation? How do I crop region for the plan?
Rotating Views On a Sheet [ 1 2 ] |
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating Views on a Sheet -180 |
Tue, Nov 5, 2013 at 9:44:26 AM
Rotating Views on Sheet |
Tue, Jan 19, 2010 at 12:30:55 PM
Rotating Project North and Sheet view North not rotating |
Mon, Oct 12, 2009 at 9:34:25 AM
Rotate Floor Plan without rotating project |
Mon, Nov 4, 2013 at 1:14:56 PM
