Forums >> Revit Building >> Technical Support >> Reporting parameter from curtain wall door in Curtain Wall Schedule
Tue, Jun 28, 2022 at 11:32:19 AM | Reporting parameter from curtain wall door in Curtain Wall Schedule
SolCor
Hello. I have created reporting parameter for a curtain wall door that are appearing in the properites but I cannot get them to report in the curtain wall schedule. Am i missing a step?
Tue, Jun 28, 2022 at 1:17:45 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
CDWdavid
5 Stars: 5 Votes
Did you set up the curtain wall door parameters as a "Shared parameter?"
Tue, Jun 28, 2022 at 1:22:55 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
SolCor
Yes I did
Tue, Jun 28, 2022 at 1:39:37 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
CDWdavid
5 Stars: 5 Votes
I did those years ago. For thses types of complicated procedures, I tried to add into my "Tips".
Those might be not exactly as your situations.
Hope can help.
162366_Create_Shared_Parameters.jpg162366_Curtain_Wall_Page_001.jpg162366_Curtain_Wall_Page_002.jpg
Tue, Jun 28, 2022 at 3:25:02 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
SolCor
those are the steps i did to create the parameter.. and I moved it to other for the store front door properties.. but the schedule still is not filling in the parameter. is it because its a storefront schedule and the family is a door in the curtain wall?
Tue, Jun 28, 2022 at 3:31:52 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
CDWdavid
5 Stars: 5 Votes
You may try, let us know.
Tue, Jun 28, 2022 at 3:57:45 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
SolCor
I may try what? I already did and the parameter is not reporting in the schedule. It shows in the curtain wall door, but not the curtain wall or schedule
Tue, Jun 28, 2022 at 8:13:31 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
CDWdavid
5 Stars: 5 Votes
https://www.revitcity.com/downloads.php?action=view&object_id=17820
Wed, Jun 29, 2022 at 7:53:09 AM | Reporting parameter from curtain wall door in Curtain Wall Schedule
SolCor
I know how to creat a door schedule.. thats not what I am trying to do. I am trying to have the door size in my storefront/curtain wall schedule.
My curtain walls are walls, not curtain sytems.. the doors have a parameter so the size is reading in the properties of the door, but not in the wall and not in the schedule.. is there a way I can do this.
Thanks.
Wed, Jun 29, 2022 at 7:51:16 PM | Reporting parameter from curtain wall door in Curtain Wall Schedule
CDWdavid
5 Stars: 5 Votes
Here is my way of doing the door schedule:
We say 100 doors for a building, Each door has a unique number. Each has its own glazing, hardware group, so on so forth.
You may have only three door types, each type has its dimension, such as, 3’-0” x 7’-0”, PR 3’-0” x 7’-0”, 3’-6” x 7’-0”. Then your door schedule for this building will have 100 door with three types. I just use the door types (which field is a “Text” just as the hardware groups) with the heading “Door Size” to populate the door schedule. The actual door size might be 4’-0”x 8’-0”, but the door type is 3’-0” x 7’-0”, which will be shown on the door schedule.
The same thing apply to the storefronts. I have 20 storefronts with 20 different sizes, but only three door sizes, 3’-0” x 7’-0”, PR 3’-0” x 7’-0”, and 4’-0” x 7’-0”.
All 20 storefronts are shown on legend, elevations with dimensions. However, there are only three types on the door schedule, the same way as the regular doors.
Revit is far from perfect, we just have to find a way to suit our needs.
Edited on: Wed, Jun 29, 2022 at 8:26:53 PM
Mon, Jul 4, 2022 at 8:49:52 AM | Reporting parameter from curtain wall door in Curtain Wall Schedule
#11
marmiketin1
4.5 Stars: 10 Votes
in the family you should make a family parameter (instance/reporting) and apply it to the dimension you want. Next, Create a shared parameter in the door family and put the reporting parameter name as the formula for the shared parameter, then create a project parameter in project using that same shared parameter and apply it to both the door and walls category, then you should be able to have it scheduled.
Mon, Dec 19, 2022 at 5:44:58 AM | Reporting parameter from curtain wall door in Curtain Wall Schedule
#12
faxedasto
Curtain Wall Panel to Curtain Wall Door
Link curtain wall parameter to curtain panel
Wed, Jun 10, 2015 at 5:06:07 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012
Thu, Jul 7, 2011 at 4:27:10 PM
Curtain wall door frame
Mon, Mar 2, 2015 at 11:37:33 AM
Curtain Wall Door Head Heights Not Displaying in Door Schedule
Thu, Aug 25, 2011 at 2:24:12 PM
Page generation time: 2.9590
