Forums >> Revit Building >> Technical Support >> phases
Wed, Feb 23, 2022 at 5:16:06 PM | phases
integrity
I work with revit 2020 LT.  I have some walls in my project that I can't select (highlight). Is this a phases problem?
Integrity
Thu, Feb 24, 2022 at 6:34:31 AM | phases
Typically that is it .... other problem could be - Is it in a linked model?
Thu, Feb 24, 2022 at 12:00:28 PM | phases
integrity
It is not linked. I've tried changing the phase settings and have not found anything that solves the problem!
Thu, Feb 24, 2022 at 12:30:07 PM | phases
Walk through your phases showing one phase at a time to see what happens.
Thu, Feb 24, 2022 at 6:23:00 PM | phases
integrity
I think I selected every opion. Nothing changes with regard to the wwalls that can't be selected.
Fri, Feb 25, 2022 at 5:38:42 AM | phases
Could this be your problem?  https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Some-elements-are-not-selectable-in-Revit-model.html
Fri, Feb 25, 2022 at 10:45:46 AM | phases
integrity
This doesn't seem to be the problem. I was able to do all the steps but the problem persists.
Mon, Feb 28, 2022 at 10:12:28 AM | phases
hanbyjm
Are there any design options set?
Mon, Feb 28, 2022 at 11:39:00 AM | phases
integrity
The design option is set to NEW. That's it! Thanks for continuing to try to solve this probem.
Wed, Mar 2, 2022 at 2:51:45 PM | phases
marmiketin1
4.5 Stars: 10 Votes
Are they Pinned and you have "select pinned elements" turned off (bottom right corner revit window)? I am assuming you cannot select the walls in any view (3D, plan, section).
Thu, Mar 3, 2022 at 9:20:50 AM | phases
integrity
That seems to solve the problem. Thanks
Capabilities to isolate phases
Tue, Nov 28, 2006 at 5:43:02 AM
Demo Plan with multi phases
Tue, Jul 28, 2015 at 7:34:43 AM
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
3D View of Phases
Thu, Feb 24, 2005 at 5:51:44 PM
Ghost Phases
Mon, Mar 24, 2014 at 5:08:46 PM
12
Page generation time: 0.1754
