Forums >> Revit Structure >> Technical Support >> column selection
Wed, Feb 16, 2022 at 2:12:29 PM | column selection
integrity
I have a Revit 2018 drawing with some columns I would like to delete. Problem is that I can't highlight the columns or a section of the roof. This is true in the floor plan, sections, and 3D. Never had this problem  before.
Carlton
Wed, Feb 16, 2022 at 4:10:08 PM | column selection
They may be in a different phase.
Wed, Feb 16, 2022 at 5:34:26 PM | column selection
integrity
Thanks. It was the phasing!
Mon, Oct 27, 2025 at 2:01:59 AM | column selection
Dan1elBr
It’s great to see such clarity on the topic and the community contributing real-world insights. I especially appreciate how you broke down the issue into manageable parts.  One suggestion: if anyone else reading this has experienced something similar, it might help to post which version of Revit you’re using (and whether it’s LT or full), since behavior can vary.
Thu, Oct 30, 2025 at 9:00:37 AM | column selection
JamieBray
I had a similar issue last year with Revit 2019 - couldn't select certain structural elements. Turned out some columns were locked in a workset or had their visibility settings messed up. Try checking your worksets tab and visibility/graphics overrides first. Sometimes switching views or using the selection filter helps too. Hope this works for you, Carlton!
Suika Game
selection window grabs wrong items
Thu, Jul 19, 2012 at 3:05:37 PM
selection issue
Fri, Mar 4, 2005 at 3:43:11 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Quit Deselecting My Selection!
Tue, Jan 13, 2009 at 10:24:45 AM
selection filter
Sun, May 21, 2006 at 9:32:56 PM
Page generation time: 2.2128
