21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> NAD83 Elevation data into topography surface??
Hi, I am trying to do a preliminary solar/view study on a friend's property (pre survey) and I managed to get data in this format (also in .csv) from the Canadian gov't:
- Data source : Canadian Digital Elevation Model
- Product(s) : Digital Elevation Model, Shaded relief, Slope map, Point data
- Output format : DEM : GEOTIFF, Derived Products : GEOTIFF, Point Data : XYZ
- Reference coordinate system : NAD83(CSRS) (EPSG:4617)
- Resolution : 0.75 arc seconds
Is there any way to convert this into what is required to make a toposurface in Revit and get it into the correct location (roughly).
A million thanks if anyone can help me with this!
-Connor
If you have it in csv, you should be able to import it. Check this out: https://forums.autodesk.com/t5/revit-architecture-forum/importing-csv-topo-file-to-revit/td-p/3310295 there is more information elsewhere.
Thanks, this helped!
I found a way to convert the NAD83 to UTM and those coordinates made the topo surface. Hard to do without GIS but there is a way.
topography... |
Sun, Jun 29, 2008 at 4:11:04 PM
Painting side surface of topography |
Tue, Feb 4, 2014 at 7:49:08 AM
Building Pad Altering My Topography Surface |
Wed, Nov 30, 2011 at 12:01:59 PM
topography elevation base |
Tue, Mar 27, 2007 at 11:34:14 PM
Topography Quality [ 1 2 ] |
Mon, Sep 21, 2020 at 7:51:10 AM
17
