28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> e-mailing uneditable Revit files??
Instead of sending my complete Revit file I'd like to just send the sheets, in an uneditable file, but I think I'd like them to still be a revit file.
Does that make any sense??
Is there such a thing??
Trying to avoid having the recipient make actual changes to the file and sending it back. Hard to track what they've changed.
I've been sending .pdf's. As simple as that is, it's an extra step I'd like to avoid. Hoping to save the Revit sheets, kind of like you do when you plot, and then forward those sheets for direct plotting from Revit on the recipients end.
I also believe I'll have fewer issues plotting to scale if plotting directly from Revit.
Post edited on 2006-06-13 23:00:21
u could try to export the acual sheets to an autocad-file. under file-menu select export, then cad format. and select one cad-format of your own choice.
keep it up
----------------------------------- Golf anyone????? |
lock/ uneditable revit families |
Wed, Jul 15, 2009 at 11:17:49 AM
E-MAILING REVIT FILE????? |
Mon, Jun 5, 2006 at 5:40:19 PM
Creating Uneditable Parameter? |
Wed, Mar 12, 2014 at 12:50:31 PM
Converting Revit files to AutoCAD files |
Wed, Sep 15, 2010 at 2:09:17 PM
HOW TO IMPORT 3DS files and DXF files into REVIT 2011? |
Sun, Nov 7, 2010 at 6:21:00 PM
