Forums >> Revit Building >> Technical Support >> showing a floor pattern for a specific room or area
Thu, Sep 9, 2004 at 9:34:14 AM | showing a floor pattern for a specific room or area
Bimman
Bimman Avatar
1 Stars: 2 Votes
i am wanting to show a cross hatch pattern for bath's, kitchen's, foyer's. but i do not want to do a filled region for all of these. is there a way to do this by selecting the room, say the same way you would place a room tag. so that it searches the boundries out on its own rather than me having to trace with a filled reagion.
PWD
Thu, Sep 9, 2004 at 3:49:26 PM | RE: showing a floor pattern for a specific room or area
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
apply the fill pattern to the floor family... then make sure that visibility is on for the fill patterns
Hiroshi Jacobs
Thu, Sep 9, 2004 at 5:36:22 PM | RE: showing a floor pattern for a specific room or area
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Also, If there is one floor going over multiple rooms you will need to use the split face tool to split the surface of the floor to individual segments and then use the paint tool to apply the appropriate materials to the corresponding rooms...
Fri, Sep 10, 2004 at 7:18:27 AM | RE: showing a floor pattern for a specific room or area
Bimman
Bimman Avatar
1 Stars: 2 Votes
split face worked great. thanks guys
PWD
Room Tags not showing up in Floor plan.
Tue, Nov 9, 2010 at 1:06:50 PM
Problem with Room Boundaring
Mon, Mar 23, 2009 at 7:55:40 AM
ROOM AREA VARIES DEPENDING ON THE DISTANCE FROM PROJECT ORIGIN
Thu, Jul 12, 2012 at 8:24:17 AM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Page generation time: 1.3876
