Forums >> Revit Building >> Technical Support >> floor plan detail level off
Mon, Nov 8, 2021 at 12:10:26 PM | floor plan detail level off
Wader
I have an odd situation where I created a new floor plan where the detail level appears just like it would if it were course even though it is set to fine.  None of the wall layers are showing up so I can pull dimensions of of the stud face and all items are grey tone.   I've adjusted the cut plane to see if that made a difference but nothing changes.  Not sure what else to check at this point.
Mon, Nov 8, 2021 at 12:17:55 PM | floor plan detail level off
Wader
I found out the issue.  When the new floor plan was created is automatically placed in on the wrong phase.  Once I changed it to the new construction phase everything appeared as it should.
thanks
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
I made a Level without a floor plan... but now I want one.
Fri, Dec 5, 2014 at 4:47:53 PM
Strangest Revit Floor Plan / Level Problem - Not a newbie question
Wed, Oct 4, 2017 at 1:59:11 PM
my 1st floor plan has not detail
Fri, Nov 23, 2007 at 10:33:32 AM
Page generation time: 10.4130
