Forums >> Revit Building >> Technical Support >> LEVEL TO SHOW SEA LEVEL (SURVEY POINT) AND RELATIVE (PROJECT BASE POINT)
Tue, Sep 28, 2021 at 12:31:31 PM | LEVEL TO SHOW SEA LEVEL (SURVEY POINT) AND RELATIVE (PROJECT BASE POINT)
ledgewood33
HOW CAN I GET A LEVEL TO SHOW SEA LEVEL (SURVEY POINT) AND RELATIVE (PROJECT BASE POINT)?
REVIT 2021
Wed, Sep 29, 2021 at 5:22:22 AM | LEVEL TO SHOW SEA LEVEL (SURVEY POINT) AND RELATIVE (PROJECT BASE POINT)
Here is one solution
https://forums.autodesk.com/t5/revit-architecture-forum/spot-elevation-level-with-both-quot-project-base-point-quot-and/m-p/7576797#M172372
Spot Elevation/ Level with both "project base point" and "survey point" 2017
Mon, Nov 27, 2017 at 5:33:42 PM
Level that reads both Project Base Point and Project Survey Point
Tue, Jun 9, 2015 at 9:39:37 AM
Topo surface points change from relative to absolute elevations [ 1 2 ]
Thu, Apr 7, 2016 at 9:33:19 AM
15
Topography Elevation from Project Base and Survey Point is Incorrect
Thu, Jan 29, 2015 at 10:32:24 PM
Project base point moved after I created levels
Fri, Jan 8, 2016 at 1:27:49 PM
Page generation time: 0.9562
