Forums >> Revit Building >> Technical Support >> Random LVT floor pattern
Tue, Sep 7, 2021 at 10:23:35 AM | Random LVT floor pattern
hanbyjm
I was wondering those of you who show floor patterns on floor finish plans, how do you show a random lvt pattern?  I worked hard on making a floor pattern with the correct size lvt but in an ashlar pattern as this was the simplist.  My boss thinks will be confusing to the people in the field even though the schedule states random pattern layout.
Wed, Sep 8, 2021 at 12:26:39 PM | Random LVT floor pattern
marmiketin1
4.5 Stars: 10 Votes
Random is pretty much impossible with the way revit patterns work unless you want to make a pat file with like 200 different line definitions for the pattern.
The best way may just be to make a filled region of you tile size and then place it in your plan with a bunch of differing orientations until it is suitable and fills the space. Other than this I think everything else would be way too time consuming.
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Parametric Wall with random void pattern
Mon, Jun 16, 2014 at 3:31:31 PM
Random stone walls
Thu, Jun 26, 2008 at 5:04:39 PM
Floor pattern -- masking floor pattern
Mon, May 23, 2005 at 11:51:48 AM
Surface Pattern on Modified Floor - No Skewing for Floor Plans
Mon, Sep 12, 2016 at 7:45:11 PM
Page generation time: 1.7691
