Forums >> Community >> Newbies >> Setting a project up to easily plot between different sheet sizes/plotters
Sun, Jul 18, 2021 at 10:22:33 AM | Setting a project up to easily plot between different sheet sizes/plotters
abenavraham
Hello everyone. I am new here and to Revit (Using Revit LT2021).
I am a residential designer and the majority of my work is for builders. I am trying to figure out the best way to set my projects up to easily switch between plotting to "B" (11x17) sheets and Arch D (24"x36") sheets. At the moment, while learnig Revi,t I am using the default template which is set up for 24x36" sheets, but I am wondering how to set it so I can switch to  plotting to 11x17 without creating a zillion sheets and duplicate views to place (for instance the first floor) on both the 11x17 as well as the 24x36 sheet. At the moment I am not seeing an easy or convient way of doing that without significantly increasing the complexity of the drawing. Also being so new ot Revit I may well be missing the obviouss solution.
Thanks to everyone for reading and I hope I am meking since of what I want to do.
Aaron
Plot settings with various sizes
Fri, Jan 28, 2011 at 11:29:52 AM
Plot Preview in PDF
Wed, Feb 22, 2012 at 11:28:24 AM
plotting revit sheet with kip plotters
Wed, Feb 20, 2008 at 6:59:30 PM
plotting issues multiple sheet sizes
Tue, Feb 15, 2011 at 7:30:45 AM
Plot log
Thu, Feb 5, 2015 at 8:06:04 AM
Page generation time: 1.8776
