Forums >> Revit Building >> Technical Support >> Step by step Etransmit
Mon, Jun 21, 2021 at 4:24:32 PM | Step by step Etransmit
CDWdavid
5 Stars: 5 Votes
Can anyone there provide a step-by-step help for how to etransmit a revit file?
After I opened a Revit file, go to Add-Ins and click eTransmit, a message "eTransmit requires all Revit models to be closed".
My question is how can I run eTransmit without open any model?
Thanks!
Tue, Jun 22, 2021 at 6:27:25 AM | Step by step Etransmit
Watch this video:https://www.youtube.com/watch?v=hyIsL0-tVr4
You may also want to read this: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-AddIns/files/GUID-2317F99F-070C-4D05-A37B-5D9488B35376-htm.html
Thu, Dec 23, 2021 at 10:47:34 AM | Step by step Etransmit
jschuster
You've probably figured this out, but in 2021 Revit after closing all files the ribbon disappears so you cannot select the Add-Ins tab. Simply click the left arrow in the upper left of the screen and it will take you to were the ribbon appears, as if you were in a project.
Thu, Dec 23, 2021 at 10:51:06 AM | Step by step Etransmit
jschuster
You've probably figured this out, but in Revit 2021, once you close all models the top ribbon disappears so you cannot click on the Add-Ins tab. Simply click the back arrow in the top left and you will see the top ribbon appear as if you had a project open.
Step by Step Guides to Buildings
Sun, Dec 7, 2014 at 7:57:47 AM
Step-by-step to finish
Tue, Dec 9, 2014 at 3:32:52 PM
step in wall
Fri, Oct 16, 2009 at 7:31:09 AM
Step by step of exporting revit model to 3dsmax for render (Vray)? [ 1 2 ]
Wed, Jun 9, 2010 at 11:31:45 PM
15
Slab Step Smart Tag
Fri, Aug 2, 2013 at 7:54:38 AM
Page generation time: 0.3618
