18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Annotation Scale is too big for my Sheet
1 Posts No Rating |
I am currently trying to create an 11 x 17 set, when i bring in my section at 1/32" the annotation is so big it is overlapping itself. Can anyone offer a way to keep my section at 1/32"=1'-0" while making my annotations at a scale closer to 1/8"=1'-0"?
Thanks
Just went thru the same situation.
There may be a better way, but you can:
select the dimension style,
select properties,
select edit/new,
select duplicate,
enter new name signifying the size of the text you intend to use,
enter new text size in the appropriate line item,
then OK your way out of the dialogue boxes.
You will have created a new dimension style with a different text size.
As far as what text size you need, I've just did a little trial and error.
This should also work for text.
Post edited on 2006-06-13 23:31:22
Post edited on 2006-06-13 23:34:58
Anyone know if there's a way to have the text and other annotation automatically scale themselves down to a smaller sheet without having to select a different dimension and text size in order to have it not overlap itself on the smaller sheets.
Haven't checked to see, but I get the feeling that once you've changed the annotations to show on the sheet satisfactorily, then it should be set to go from then on without any additional fuss.
Any comments??
annotation symbols scale |
Thu, Feb 12, 2009 at 2:06:54 PM
scale check |
Tue, Oct 23, 2012 at 5:05:08 AM
Maintaining Embedded Text Location Regardless of Scale within a Family |
Tue, Jan 31, 2012 at 5:37:05 PM
How to display N.T.S. with title on a Sheet? |
Tue, May 10, 2011 at 4:31:24 PM
Templet |
Sun, Oct 28, 2012 at 5:15:08 AM
