37 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> Room area blanc
Dear experts,
what could be a reason if an Area and Perimeter cells are blanc in the room schedule - only for a several rooms.
Other rooms in the same schedule are good.
it is neither Not Placed nor Not Enclosed. Just empty.
Please help. It is Revit 2020.
Sorry not sure why but I would delete them in the schedule view and replace them in the floor plan.
Perhaps your rooms are really not enclosed.
Are your walls room bounding or are you useing room seperation lines. If lines, then bake sure they close.
Also, Make sure room bounding walls interxect the floor level. If they are even just above the level, then they will not work as room bounding.
Sorry, it does not allow to type my reply.
Thanks - i think the best option is to delete them from the schedule and place new ones.
If they were not enclosed, there would be "Not Enclosed". But the cells are just white.
Thanks again
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
room area calculation |
Thu, Jan 15, 2009 at 5:51:20 AM
ROOM AREA VARIES DEPENDING ON THE DISTANCE FROM PROJECT ORIGIN |
Thu, Jul 12, 2012 at 8:24:17 AM
room area calculations |
Tue, Nov 4, 2008 at 3:48:50 PM
