Forums >> Revit Building >> Technical Support >> Default Level of Template
Thu, May 6, 2021 at 11:29:37 AM | Default Level of Template
CDWdavid
5 Stars: 5 Votes
I have created several templates, and suddenly one of them change the default level to 2nd floor. When I need to place a new architectural wall, it alway on the 2nd level, all other templates are still starting on the 1st level. It bothers me a lot.
Please help!
2020.1.
Edited on: Thu, May 6, 2021 at 11:32:43 AM
Thu, May 6, 2021 at 2:54:11 PM | Default Level of Template
Templates do not change themselves, they are as they were created or modified by someone.
So, edit the template to what you want.
Mon, May 10, 2021 at 2:50:03 PM | Default Level of Template
marmiketin1
4.5 Stars: 10 Votes
I am assuming you are talking about if you draw a wall in 3D then the base constraint is defaulting to Level 2? When drawing in a plan view the base constraint should be defaulting to the associated level.
I would check to make sure the plan views are named according to their base constraints.
Other than that you could go to an elevation/section and then move the level 2 down to the level 1 location and vice versa and then rename them correctly.
Underlay using construction template on 2012 version
Thu, Nov 28, 2013 at 1:07:12 PM
View Template Object Visibility Problem
Sat, Feb 26, 2011 at 2:53:16 PM
Changing .rte template midstream
Thu, Feb 14, 2008 at 1:03:47 PM
metric template
Mon, Apr 5, 2010 at 7:04:51 AM
recit 2012 default template link - Rmy
Mon, Mar 3, 2014 at 7:50:02 AM
Page generation time: 4.5892
