Forums >> Revit Building >> Technical Support >> Door wont cut into in place model wall.
Tue, Apr 20, 2021 at 7:02:56 PM | Door wont cut into in place model wall.
QUINNJ
So we have regualr wall joined to an inplace model wall same materials etc... when we place door into the regular wall the inplace model wall wont cut and vice veruss we put door into inplace model wall the regular wall wont cut. Is there any way to get the door to cut both?
Wed, Apr 21, 2021 at 12:40:17 PM | Door wont cut into in place model wall.
"In-place model wall" - What do you mean. A wall done by extrusion vs using the wall tools?
Are these two different door placements or is this one door than intesects two walls?
Thu, Apr 22, 2021 at 10:58:18 AM | Door wont cut into in place model wall.
QUINNJ
The in place model a solid extrusion is set to category wall. The inplace model solid extrusuion is next to an actual wall. The 2 then were joined geometry.  If you place the door in the inplace model extrusion it wont cut the regular wall. If you put the door in the regular wall it wont cut the in place model extrusion.
Fri, Apr 23, 2021 at 5:59:33 AM | Door wont cut into in place model wall.
Again, I need some clarification.
Are you saying that once you place a door in either wall, saw the normal wall, that door family can no longer be used in the other wall type, the extruded one?  <<< If this, then report to Autodesk.
Or is this one door than intersects two walls, the normal wall and the extruded wall?  <<< If this ... I don't see any way Revit could or should be set up to do this.  Just too rare of a condition.  Place the door in one wall and add your own opening in the other.
Edited on: Fri, Apr 23, 2021 at 12:22:54 PM
Mon, May 3, 2021 at 10:21:46 PM | Door wont cut into in place model wall.
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
QUINNJ, see pix for the solution.
door not cutting wall
Mon, Apr 6, 2015 at 10:24:32 AM
DOOR CUT PROBLEM IN PLAN
Thu, May 4, 2006 at 7:34:59 AM
Model in in place walls and Doors
Thu, Mar 23, 2017 at 3:19:24 PM
Door can't cut wall
Thu, Jun 14, 2007 at 12:02:14 AM
built door in "general model wall based" family - now what?
Thu, Oct 30, 2008 at 3:46:07 AM
Page generation time: 1.3171
