14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Add Vuew Scakes for Model Line Weights
Good morning everyone,
for adding a scale for line weights chart,
In Revit 2020, point 3 of Help suggests to "select a scale value, and click OK". I think it means "select from the drop-down list".
Is it possible to create columns for special scales, e.g. 1:125, or 1 5?
Thank you,
was intended to be 1 5.
The idea is to add a scale that is not predefined.
Thanks
To Add a Custom Scale to the Scale Drop-Down List
- Choose Options from the Application menu to open the Options dialog box.
- Select the User Preferences tab, and then click the Default Scale List button at the bottom of the dialog box.
- In the Default Scale List dialog box, click the Add button.
Thanks a lot!
Thanks a lot!
{It is soooo difficult to submit an entry here}
Sorry can't find it. I have Optios under File. There are UserInterface settings. Could you show a screenshot?
Detail Lines Follow Model Line Weights Problem |
Fri, Sep 9, 2011 at 9:55:51 AM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Line weights with Custom Scales |
Wed, Aug 16, 2017 at 12:09:53 AM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
A Nice set of Revit Line Weights |
Wed, Jun 20, 2007 at 8:47:36 PM
