Forums >> Revit Building >> Technical Support >> CRAWL SPACE
Mon, Jun 12, 2006 at 9:49:35 AM | CRAWL SPACE
Thread Post Kudo! #1
BRIANDHADLEY
1 Stars: 1 Votes
HOW IS THE BEST WAY TO CREATE AN EXCAVATION FOR A CRAWL SPACE? I HAVE BEEN USING THE PAD TOOL BUT I DON'T WANT TO SHOW A PAD.
Mon, Jun 12, 2006 at 6:52:14 PM | RE: CRAWL SPACE
gregmeurer
4.5 Stars: 9 Votes
If I get you right you want more room under the house....ie crawl space. The best way to do this I think without creating a floor would be to just create a topo area under the house and have the points at the level you need them at. Then just extend the walls or if your using a foundation, to the level that the topo is at. Hope this works
Mon, Jun 19, 2006 at 12:24:20 PM | RE: CRAWL SPACE
BRIANDHADLEY
1 Stars: 1 Votes
I HAVE TRIED THIS BUT I GET A GRADUAL SLOPE. I WANT THE GRADE TO BE 6 INCHES BELOW THE TOP OF THE FOUNDATION ON THE EXTERIOR SIDE OF THE FOUNDATION WALL THEN AT LEAST 18 INCHES BELOW THE BOTTOM OF THE FLOOR JOISTS ON THE INSIDE OF THE FOUNDATION WALL.
Mon, Jun 19, 2006 at 1:16:04 PM | RE: CRAWL SPACE
gregmeurer
4.5 Stars: 9 Votes
What you have to do with the topo is, put a point on the exterior side of the wall (on the wall) and make it -6" and then on the interior side of the wall (on the wall) the points should be a -18". when you are in the SITE view you will see that the slope takes place within the wall it's self.
Mon, Jun 19, 2006 at 5:12:29 PM | RE: CRAWL SPACE
puzzle
4 Stars: 10 Votes
To find the elevation of your slab use the spot dimension tool in drafting.
Macca
Sunshine Coast
QLD Australia
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
Help! 14 Meg Project in CD's slowing to a crawl!
Tue, Oct 7, 2008 at 10:11:08 AM
floor to wall connection detail
Mon, Jan 25, 2010 at 2:55:03 PM
Importing .dwg Details - Model Space vs. Paper Space
Wed, Aug 9, 2006 at 5:37:45 PM
Where does it start and ends the slab?
Wed, Dec 23, 2009 at 1:59:36 AM
Page generation time: 0.1538
