Forums >> Revit Building >> Technical Support >> ''Visibility grafics'' and ''create parts'' problem when mak
Wed, Mar 17, 2021 at 2:59:17 AM | ''Visibility grafics'' and ''create parts'' problem when make sections.
giovanni22
Hi!
Let me search to explain a problem that I have.
I have a series of wall that I want the external part (thats why I made ''create parts'' for these walls ) to be lower than the internal part (that seats on the floor). And all works fine till I made a Section of the building and I made ''Visibility/grafics ovveride'' in order to make the section walls with darker color.
And here there is the problem that Revit doesnt allow me to ''dark'' the walls when the ''parts visibility'' at the section is ''show parts'' but only when ''show both'' and the external part of the wall that goes bellow the internal part stays white.
Or is something that I dont do correctly?
I hope that I explained clearly the problem.
Wed, Mar 17, 2021 at 7:44:08 AM | ''Visibility grafics'' and ''create parts'' problem when mak
Some images may help us to understand.
Parts may not have been the best tool.  You can control walls by layers.  https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-Model/files/GUID-CCDEE011-2A5E-43AC-BD60-8F81CF432A6B-htm.html
Walls with layers defined differently is shown below.
Thu, Mar 18, 2021 at 2:12:06 AM | ''Visibility grafics'' and ''create parts'' problem when mak
giovanni22
Thank you.
I will look the solution you propose.
I include three pictures. Their names are regarding the ''parts visibility''.
On ''show original'' the ''visibility graphics overrides'' (to make the section wall darker) work  but I dont have the external part go lower.
On ''show parts'' the ''visibility graphics overrides'' doesnt work and the only solution here  is  ''overides graphics in view'' for every part of the wall.
In ''show both'' the ''visibility graphics overrides'' works but the external part that is lower, remains white.
Edited on: Thu, Mar 18, 2021 at 2:13:37 AM
Thu, Mar 18, 2021 at 6:08:55 AM | ''Visibility grafics'' and ''create parts'' problem when mak
Are these two seperate walls?
This may help you: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/125e85cb-b755-4e2f-a82d-b32595ba34d2.html
Fri, Mar 19, 2021 at 2:36:48 AM | ''Visibility grafics'' and ''create parts'' problem when mak
giovanni22
Hi!
Thank you for the video.
In all the photos its the same wall (which has two parts). Only the external part is a gutter like in this photo.
Edited on: Fri, Mar 19, 2021 at 2:37:57 AM
Fri, Mar 19, 2021 at 8:30:45 AM | ''Visibility grafics'' and ''create parts'' problem when mak
Wow - who would have thought that this was a plan section, not a vertical section?  I certainly thought it was vertical since you said nothing about orientation.
Now you need to understand wall layer function and how to control it.  Here is a beginning: https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-1CCD1005-CBDA-4338-8D60-489095D4BB25
This tool should solve many problems for you if you use it faithfully.
Fri, Mar 19, 2021 at 9:30:10 AM | ''Visibility grafics'' and ''create parts'' problem when mak
giovanni22
I am sorry! My english is not the best.
You understood correctly the first time. Its a vertical wall section.
Fri, Mar 19, 2021 at 10:09:20 AM | ''Visibility grafics'' and ''create parts'' problem when mak
Όχι, στην τελευταία σας εικόνα, λέτε ότι το στρώμα στα αριστερά είναι μια υδρορροή. Επομένως, αυτό πρέπει να είναι ένα σχέδιο, όχι μια κάθετη τομή εκτός αν με υδρορροή, εννοείτε ένα κάτω στόμιο.
Óchi, stin teleftaía sas eikóna, léte óti to stróma sta aristerá eínai mia ydrorroí. Epoménos, aftó prépei na eínai éna schédio, óchi mia kátheti tomí ektós an me ydrorroí, ennoeíte éna káto stómio.
Edited on: Fri, Mar 19, 2021 at 10:21:19 AM
Fri, Mar 19, 2021 at 11:45:46 AM | ''Visibility grafics'' and ''create parts'' problem when mak
giovanni22
My apologies!
Al three photos are vertical sections of a wall consisted of two parts.
The external part like you said is the lower part of a down spout.
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Permanently unchecking the 'Editable Only' box
Mon, Oct 27, 2008 at 11:39:20 PM
Sheet 'X' of 'Total Number of Sheets'
Wed, Jun 5, 2013 at 4:39:34 PM
Can't find ''Rectangle Panel - MPK''
Thu, Apr 3, 2014 at 5:50:24 AM
Page generation time: 4.4880
