Forums >> Revit Building >> Tips & Tricks >> add height label to outlet symbol (2019)
Fri, Feb 19, 2021 at 9:44:30 AM | add height label to outlet symbol (2019)
ledgewood33
i would like to add a label to the outlet  family for the height of the outlet. it would be similar to the label for the GFI designation. i try to follow how the GFI label was applied but i cannot get it to work for the height label. has anyone tried this with success?
Mon, Feb 22, 2021 at 7:45:41 AM | add height label to outlet symbol (2019)
marmiketin1
4.5 Stars: 10 Votes
Can you post the family you currently have and for clarification is this a modeled outlet family that shows the outlet symbol when in plan view or is it just the outlet symbol?
Mon, Feb 22, 2021 at 8:18:41 AM | add height label to outlet symbol (2019)
ledgewood33
attached is the family. it is the modeled family with the nested symbol family in it. it is the out of the box family that i want to modify
Mon, Feb 22, 2021 at 11:46:51 AM | add height label to outlet symbol (2019)
marmiketin1
4.5 Stars: 10 Votes
The issue was that in Revit the origin of the family is assocciated to reference planes and not the level line in the family. And in the family you had the "Placement Height" parameter dimensioning from the level line to the reference plane.
What i did to fix this was create a reference plane at the level line and locked it. Made that reference line the origin and then dimensioned from that to the centerline of the outlet. Now when you adjust "Placement Height" parameter it will adjust correctly. Also becasue of this you need to always make sure default elevation is set to 0.
label parameter formula
Thu, Apr 26, 2012 at 12:15:03 PM
Label in Outlet-GFI Family Revit 2009
Tue, Jan 27, 2009 at 1:38:11 PM
Tagging in a family
Mon, Jan 2, 2006 at 4:18:05 PM
Label height parameter of power point family
Thu, Oct 16, 2008 at 9:02:48 PM
Parametric Electrical Symbol
Wed, Jun 16, 2010 at 6:21:47 PM
Page generation time: 2.9984
