Forums >> Revit Building >> Technical Support >> Room Finish Schedule - Linked
Wed, Feb 17, 2021 at 6:50:05 AM | Room Finish Schedule - Linked
vrmoreno3
We have a very complex model with different portions linked into a master file. We are not ready to bind due to the complexity at this time. In lieu of constantly unloading, opening the link to edit room finishes, is there a program that will allow us to edit those within the master without the constant unloading and reloading of the lnks? And hey go back to the linked files?
Wed, Feb 17, 2021 at 9:01:34 AM | Room Finish Schedule - Linked
First, you never need to unload the file.
Second, When I had this problem, I just opened the two files at the same time, made the change in the appropriate file then saved.  Then you switch back to the other file and reload the link.
Wed, Feb 17, 2021 at 3:17:39 PM | Room Finish Schedule - Linked
vrmoreno3
Opening a linked file still says that it will unload the link in order to proceed. I thought I had searched out a addin that would allow a schedule to be edited including the links. There were be many instances where I will need to change the room name, number, and a code we use to track space usage. The constant back and forth is becoming tasking.
Wed, Feb 17, 2021 at 3:52:40 PM | Room Finish Schedule - Linked
Are you working in a cloud file?  If so, maybe this will help you.  https://revitforum.org/showthread.php/43316-Revit-2020-Open-more-than-one-Cloud-Models-in-a-single-session
Otherwise, this may help.  http://do-u-revit.blogspot.com/2013/06/opening-linked-models-for-editing.html
I always opened the second file in a new Revit session.
Room finish Schedule showing Deleted Rooms
Wed, Aug 26, 2009 at 3:56:37 PM
Revit 2016 Room finish schedule and material schedule
Thu, Mar 9, 2017 at 3:41:41 PM
Room finish schedule question
Wed, Jul 8, 2009 at 3:33:52 PM
Renumbering rooms -- rooms out of numeric order on Room Finish Schedule
Thu, Dec 10, 2015 at 11:01:57 AM
Finish Material Schedule
Tue, Nov 29, 2005 at 12:31:59 PM
Page generation time: 4.7188
