Forums >> Revit Building >> Technical Support >> How to Tag all rooms at the same time
Mon, Jan 25, 2021 at 8:41:49 AM | How to Tag all rooms at the same time
madsenk
I am using 2020
Mon, Jan 25, 2021 at 10:50:29 AM | How to Tag all rooms at the same time
https://revitconvert.wordpress.com/2012/04/17/tagging-rooms-all-at-once/
Mon, Jan 25, 2021 at 11:45:20 AM | How to Tag all rooms at the same time
madsenk
WWhub,
This link is for the solution for 2012, and I am using 2020, and this tread/link you sent doesn't work for 2020
Mon, Jan 25, 2021 at 3:18:33 PM | How to Tag all rooms at the same time
Here is Autodesk's response for 2020 - same as for 2012: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-DocumentPresent/files/GUID-13EA386B-E613-4126-B634-67BEC622177E-htm.html
Mon, Jan 25, 2021 at 4:32:59 PM | How to Tag all rooms at the same time
madsenk - At least click on my new link, don't just repost your last post.
Thu, Jan 28, 2021 at 7:05:16 AM | How to Tag all rooms at the same time
madsenk
WWhub,
Thu, Jan 28, 2021 at 8:14:31 AM | How to Tag all rooms at the same time
@madsenk - I don't know what your problem is, maybe you don't know how to click on a link.  The link I posted has this at the top.
NOTE:  2020
Fri, Jan 29, 2021 at 7:04:13 AM | How to Tag all rooms at the same time
hanbyjm
Is this what you want to do?  Too Simple
Thu, Feb 4, 2021 at 10:10:50 AM | How to Tag all rooms at the same time
madsenk
Hanbyjm,
That process does not work in 2020, thanks anyways!  Simple-not!
Thu, Feb 4, 2021 at 10:36:57 AM | How to Tag all rooms at the same time
madsenk
Here is the solution:
In Properties, go to Underlay, select Range Base Level, and change it to the Base level you are on, then you will see all of the tags for each rooms that have been tagged all at the same time.
Thanks for everyones help!
Thu, Feb 4, 2021 at 11:25:29 AM | How to Tag all rooms at the same time
First mention of an underlay.  No wonder the solution didn't work, we were not told everything.
Edited on: Thu, Feb 4, 2021 at 11:27:17 AM
Room Tags - Tagging all Rooms at Once??
Mon, Sep 17, 2012 at 11:40:17 AM
two seperate rooms but with one room tag
Thu, May 22, 2008 at 6:56:07 PM
Tag Rooms in ceiling plan
Mon, Sep 9, 2013 at 9:43:05 AM
Tag Suite and Maintain Rooms
Mon, Oct 28, 2013 at 8:58:38 AM
Room Tag issue
Mon, Aug 31, 2009 at 9:21:14 AM
Page generation time: 0.5175
