Forums >> Revit Structure >> Technical Support >> Title Block parameters
Fri, Jan 8, 2021 at 7:00:23 AM | Title Block parameters
simon1688
I have created a title block family with some extra title block data parameters is there a way to import this into a project with the title block instead of adding the parameters afterwards into the project.
Revit 2014 user
Fri, Jan 8, 2021 at 7:51:40 AM | Title Block parameters
marmiketin1
4.5 Stars: 10 Votes
Any parameters created for titlelock families are going to be shared parameters. If you want them to work they will always need be loaded into the project as well. Unfortunately there is no way around this as there are several things associated with shared parameters that must be applied in the project which are not able to be done in the family.
shared parameters vs lables on a title block
Tue, Feb 8, 2011 at 2:30:45 PM
project title block
Tue, Dec 1, 2009 at 2:18:45 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Shared Parameter In Annotations
Tue, May 22, 2018 at 5:44:20 PM
Title Block Labels
Wed, Feb 14, 2007 at 11:52:49 AM
Page generation time: 0.2096
