Forums >> Revit Building >> Technical Support >> IFC Export with all structural information
Wed, Jan 6, 2021 at 6:50:50 AM | IFC Export with all structural information
bravo33
I am trying to export a Revit structural model (specifically the steelwork element) to IFC and retaining all element perameters.
The steel beams show all the parameters (cut length, type, weight etc. ie UB533x210x82) but the columns do not show this information.
The information is in the Revit model but not exporting.
Any help appreciated.
Mon, Jan 25, 2021 at 7:11:58 AM | IFC Export with all structural information
edhilliam
Did you manage to find a soluton to this? I am having a similar problem when I export plates. The material parameter and some project parameters I created are not exporting into IFC from Revit 2019.
Tue, Jan 26, 2021 at 10:33:01 AM | IFC Export with all structural information
hanbyjm
Are they shared or project parameters?
Wed, Jan 27, 2021 at 3:05:14 AM | IFC Export with all structural information
edhilliam
It is the structural material parameter and some project parameters I am having trouble with.
Revit MEP IFC Export - Objects not detalied
Wed, Jul 2, 2014 at 8:08:29 AM
Revit Family Export to IFC
Fri, Nov 29, 2013 at 4:29:41 PM
IFC export: Gross Area
Fri, May 29, 2009 at 3:01:19 AM
IFC Export - Unrecoverable Error - Aborted
Wed, Feb 26, 2014 at 8:15:09 AM
IFC structural model behind walls
Thu, Apr 26, 2018 at 4:52:10 AM
Page generation time: 0.2845
