Forums >> Revit Building >> Technical Support >> Want Heavy Boundray at Reflected Ceiling
Thu, Dec 10, 2020 at 8:38:32 AM | Want Heavy Boundray at Reflected Ceiling
cboersen
I want my ceiling boundary lines in a reflected ceiling plan to be very heavy.  The problem is that the walls hide half of the line thickness.  I can make the walls transparent and see the full line but that is not really a look I like.  How do I make it so the ceiling boundary line is "on top" of the wall?
Fri, Dec 11, 2020 at 7:42:47 AM | Want Heavy Boundray at Reflected Ceiling
Draw order on these elements has always been a problem and I don't see that this has changed.
Maybe a workaround for these views only.  How about copying the ceiling sketch and re-inserting as detail lines?
Fri, Dec 11, 2020 at 10:12:48 PM | Want Heavy Boundray at Reflected Ceiling
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Have you tried printing? It should print correctly. The image on the left is a pdf print out, on the right - revit screen shot (heavy line ceiling enclosed within three walls - RCP).
Reflected ceiling plan
Fri, Mar 28, 2008 at 11:16:26 AM
Cannot open reflected ceiling plan
Fri, Jan 9, 2009 at 2:23:07 PM
Reflected Ceiling Plans
Mon, Aug 22, 2011 at 9:57:26 AM
REFLECTED CEILING PLAN
Thu, Jan 20, 2011 at 3:12:51 AM
Problem seeing doors in reflected ceiling plan
Mon, Jul 14, 2008 at 9:26:12 AM
Page generation time: 2.1728
