27 Users Online (25 Members):
Forums >> Revit Systems >> Technical Support >> I can't assign a switch ID to a switch
I enter a switch ID, then there is a warning stating it is not found, and no switch ID appears on the switch I am assigning a switch ID. I have search the net a bit, could not find any useful answer yet. I have just found another user came across the same or a similar issue and solved it, but I could not get what S/he means by "the switch labels were not loaded into the project" or how s/he loaded it. Any advice would be appreciated. Thanks in advance.
https://forums.autodesk.com/t5/revit-mep-forum/switch-id-tag/td-p/7015500
Switch ID Grayed out in Revit MEP |
Tue, Feb 26, 2013 at 11:33:36 AM
grey out switch ID |
Fri, Jul 12, 2013 at 8:23:25 AM
3GB memory switch |
Mon, Apr 7, 2008 at 5:41:13 AM
Video cards that work with 2009 & 3 meg switch |
Thu, Oct 30, 2008 at 2:45:25 PM
11
3mb memory switch |
Fri, Apr 4, 2008 at 9:33:12 AM
