Forums >> Revit Building >> Technical Support >> trimming walls to underside of stairs
Sat, Jun 10, 2006 at 9:31:47 AM | trimming walls to underside of stairs
ICON
5 Stars: 3 Votes
Had seen a procedure for this that seemed kind of involved. All I do is ckick on wall and "edit profile" align the purple line defining the top of the wall with the bottom of the stair carriage. Is this a vaild approach or should I anticipate some unforeseenproblems down the road as the model progresses
Sat, Jun 10, 2006 at 5:35:33 PM | RE: trimming walls to underside of stairs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The involved process you speak of was regarding attaching a curved wall to curved stairs. rather than edit profile, i just draw a reference line at the same angle as the stair and then attach the wall to this...
Sun, Jun 11, 2006 at 11:29:52 AM | RE: trimming walls to underside of stairs
ICON
5 Stars: 3 Votes
Thanks, do you anticipate any problems with just editing wall profile. I'll try the refence line. Have I got it right that you'd be able to attach the reference line to the carriage resulting in a wall that updates as the stair carriage is moved around.
Mon, Jun 12, 2006 at 9:09:37 PM | RE: trimming walls to underside of stairs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No. Don't believe you'll be able to constrint the reference plane/line to the stair though...
Tue, Jun 13, 2006 at 1:20:21 PM | RE: trimming walls to underside of stairs
ICON
5 Stars: 3 Votes
Thanks for your input.
Attaching walls to stairs
Tue, Aug 22, 2017 at 12:20:10 AM
13
Trimming Walls to a slope
Fri, Feb 24, 2006 at 2:57:04 PM
Attaching Curved walls to underside of Curved Stairs
Wed, Sep 12, 2012 at 12:43:47 PM
Attaching walls to the bottom of stairs
Wed, Aug 24, 2011 at 10:15:55 AM
cantilevered stone stairs
Thu, Feb 22, 2018 at 2:30:39 PM
Page generation time: 6.4635
