Forums >> Revit Building >> Technical Support >> how to tag new vs existing door/windoew of the same kind.
Thu, Nov 19, 2020 at 8:59:40 PM | how to tag new vs existing door/windoew of the same kind.
brankulo
revit will not let me have different tags for same door family on different phase? whats the trick here? say i have 3x7 new door taged 01. than i have exact same door that is existing that i want to tag "(E)". its not possible even though they are on different phase. any idea how to do this?
thanks
Fri, Nov 20, 2020 at 5:33:22 AM | how to tag new vs existing door/windoew of the same kind.
The door property (tag - siz - type etc) belongs to the phase and can only be altered in that phase.
Perhaps this can help you: https://forums.autodesk.com/t5/revit-architecture-forum/phases-for-doors-different-door-angle-between-phases/td-p/7935008
Fri, Nov 20, 2020 at 3:04:13 PM | how to tag new vs existing door/windoew of the same kind.
CDWdavid
5 Stars: 5 Votes
Here is my work-around.
I created a new tag for existing doors, then do followings:
1.  While placing the door, click “Tags” in the Option Bar.
2. In “Loaded Tags And Symbols”, under “Doors” Category, click “Loaded Tags”, then, switch between “Door Tag-AAA”, and “Ex Tag-CCC”.
Edited on: Fri, Nov 20, 2020 at 3:06:13 PM
door tag
Thu, Feb 17, 2005 at 8:51:59 PM
How to create new Door Tag to our requirement?or edit existing
Thu, Sep 16, 2010 at 5:23:09 PM
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Page generation time: 2.8248
