25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Create Line type
I have a skecthed line for my grass. Is there a way to turn it into a line time. Thanks for any help.
A line is linear .... so no, you can not make this a line. It can be a detail element and you can make a repeating detail out of that. Search for how to do that using the search feature.
Thanks for the information. Will look at doing that.
Here is a Line Based detail family I created which also does the trick. Works for any length of line even short ones.
Says file was saved in a later version and cannot be retrieved. I am using 2019.
Whoops, my bad. I was using 2020. Here is a 2019 version.
That is cool. Thank you.
Create a Fence Line Type [ 1 2 ] |
Mon, Feb 8, 2016 at 3:41:51 PM
15
Sloped joist line type |
Thu, Nov 25, 2010 at 12:25:02 PM
Change CMU line type globally |
Thu, Mar 13, 2008 at 6:18:04 PM
Line Type Weight Will Not Change, Overrides Set Will Not Show [ 1 2 ] |
Sun, Dec 13, 2020 at 11:51:32 AM
17
new line type / existing dtl component |
Wed, Nov 25, 2020 at 9:53:14 AM
