Forums >> General Discussion >> Revit Project Management >> What is the best laptop for using revit like software?
Tue, Oct 6, 2020 at 2:23:00 AM | What is the good laptop for using revit like software?
JohnLu01
I am new user of revit software. I have lenovo dual core t400 laptop. But it is very slow when i run softwares like autocad or revit. Then i search on google and find a list specially for revit laptops.
Now i am bit confused which laptop to buy. My budget is $500. Please suggest me which laptop is best in this budget.
Thanks
Edited on: Wed, Oct 7, 2020 at 12:39:58 AM
Edited on: Tue, Jan 5, 2021 at 3:49:21 PM
Wed, Oct 14, 2020 at 6:10:45 AM | What is the best laptop for using revit like software?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Start by managing your model better by trying to reduce its size as much as possible. Purge it. Save it using compression. Export your families and reduce their size as much as possible then import them back in ( purge them too). Remove linked in DWGS or images etc. Remove redundant content.
$500 is a pretty low budget for a Revit laptop. I would start at $1800. If this is beyond your means, then you should go for a PC as you will get more bang for your buck.
Specifications to be aware of:
1) CPU should be high frequency. Revit only uses one core in the CPU ( except in rendering)
2) RAM should be 16GB min.
3) GPU should be as much as you can afford. Revit prefer's NVidia GPU's but others work too.
The Revit Guy is pretty bang on with this video citing an Origin laptop. ( https://www.youtube.com/watch?v=TuRxn2G4PQw)
I can only recommend a Dell G7 as I have had tremendous success with them. Get one with a Max-Q GPU.
Troubles registering old Revit standalone on new computer
Tue, Oct 13, 2020 at 2:03:34 PM
Want to buy a Laptop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mon, Jan 30, 2006 at 4:26:53 PM
14
old laptop
Tue, Jul 10, 2007 at 12:37:15 PM
laptop setup for revit [ 1 2 ]
Thu, Oct 19, 2006 at 10:06:52 AM
21
Using Revit on a touchscreen laptop
Wed, Feb 1, 2017 at 10:30:54 AM
Page generation time: 3.1500
