27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Can I export a 3D revit file(fbx,obj,etc) with annotations(door/window tags)?
0 Posts No Rating |
I am able to see annotations(door,window tags) while using a locked 3D view in Revit but when I am exporting it to a 3D object file such as *.fbx or *.obj then those annotations are not visible in the exported file. Floor level are still visible in the exported file but annotations are missing. Is there a solution to this? Please help!
0 Posts No Rating |
Got a workaround. Now I am putting 3D text in my component family and associating it with the required tag parameter so that when I load it into my project the 3D text embedded into the component shows the tag value. Also I have put a visibility parameter for the text in the family file itself to control the visibility of the text as an when required in the project.
Exporting FBX file from Revit to 3Ds Max |
Wed, Sep 30, 2020 at 1:36:49 PM
Room Window and Door Tags |
Thu, Nov 15, 2007 at 9:21:10 PM
Export to *.obj |
Sun, Jul 14, 2013 at 8:59:31 AM
Transfering door and window tags to Sheet File |
Tue, May 8, 2007 at 2:13:35 AM
Fireplace doesn't export out into STL file |
Sat, Jan 24, 2015 at 9:24:41 AM
