Forums >> Revit Building >> Technical Support >> rated walls using filters
Sat, Sep 12, 2020 at 6:33:02 AM | rated walls using filters
ennisdavis23
I cant get the rated wall to work using the filters, .pat files and visibility graphics routine. Tried differed scales in the pattern, different orientations, course display but it comes out solid or fine. I need the dashed wall type. What am I doing wrong?
Wed, Sep 23, 2020 at 3:55:13 AM | rated walls using filters
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Use a solid fill. Red, green, orange, yellow. A wall is tiny in cut plan. Filling it with a tiny pattern will just end up as a blur.
Check you have the filter set up correctly. Are walls category selected in drop down on right?
Follow link below for overview.
https://blogs.rand.com/support/2013/09/revit-using-filters-to-show-fire-rated-walls.html
Fire Rated Walls Plan
Sat, Sep 8, 2012 at 11:31:19 PM
cut patterns on existing walls
Wed, Jan 30, 2008 at 3:56:01 PM
Line Type for fire rated Walls [ 1 2 ]
Wed, May 6, 2015 at 7:41:10 AM
16
Walls in a Linked Model
Tue, Jul 31, 2012 at 12:45:30 PM
12
Walls layers + phase filters display problem
Wed, Dec 21, 2005 at 5:40:14 PM
Page generation time: 2.0038
