22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> HP Design Jet 450 (E/A0) printing errors
hi
I've been having problems with my plots from Revit using the HP450... For some reason, the spooler crashes although print jobs from ACAD are carried out effortlessly. We've recently installed a print server and use a port address to configure prints.. Are there any fixes in particular for this plotter? Please advise!
Thank you.
4 Posts No Rating |
Hi Gautam!
Great to see you in Revit forums :D
reg. your printing problems, you might have already figured out the reasons (its been a while since u posted!). just in case...
if you have big imported files in ur Revit sheet(images, dwg) that you are trying to print, that might be one of the reasons. you could convert your revit sheet to pdf and print it.
Hope this helps!
Suganya
Yes we have a 450c too- we found that plotting times were greatly reduced(especially with shaded images) by converting to dwf or pdf and then plotting
Problems printing to HP 1055 |
Thu, Dec 6, 2012 at 8:54:54 AM
Printing Problems Revit 2012 |
Wed, May 16, 2012 at 7:31:01 AM
Private Jet |
Mon, Jul 2, 2007 at 5:12:50 PM
Printing Lighting Plans in Revit MEP |
Mon, Mar 14, 2011 at 9:20:35 AM
HP DESIGN JET 1050C FOR VISTA 64 BIT |
Fri, Apr 18, 2008 at 6:39:35 PM
