Forums >> Revit Building >> Technical Support >> Internal Origin NOT At 0,0,0 ?
Mon, Aug 31, 2020 at 5:37:27 PM | Internal Origin NOT At 0,0,0 ?
KaylaKirchberg
Hello,
I moved my project base point & survey point to the internal origin. (Right Click -> "Move To Internal Origin") I was hoping this would be at (0,0,0), but when I select the project base point it reads at 778'-8" Elev (See Screen Shot). Have I accidentally moved the internal origin? I thought it was always at 0,0,0?  Is there a way I can reset it?
Thanks in advance for any feedback Smile
P.S. I'm using Revit 2020.2
Edited on: Mon, Aug 31, 2020 at 5:53:34 PM
Edited on: Mon, Aug 31, 2020 at 5:54:08 PM
Tue, Sep 1, 2020 at 7:25:21 AM | Internal Origin NOT At 0,0,0 ?
You need tyo spend some time reading the information here and in the other linked items concerning Project Base Point and Survey Base point:  https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-Model/files/GUID-363D008B-69DF-4FAA-AA01-6BE9C10267A8-htm.html
Origin to Origin
Tue, Jul 5, 2011 at 8:18:16 AM
Point Clouds Origin to Origin
Tue, Nov 8, 2011 at 11:23:30 AM
Export insertion point???
Wed, May 3, 2006 at 11:06:46 PM
Acad Import - Origin to Origin
Wed, Aug 1, 2007 at 5:57:25 PM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
Page generation time: 0.9605
