Forums >> Revit Structure >> Technical Support >> Brace goes Wrong?! wrong connections
Mon, Aug 31, 2020 at 8:17:01 AM | Brace goes Wrong?! wrong connections
behzadmb
hey, i'm attempting to use a brace to connect a columns and a beam together, but it picks the wrong beam all the time, i tried to press TAB on the keyboard but nothing has changed. can you tell me what should I do?
Mon, Aug 31, 2020 at 3:06:09 PM | Brace goes Wrong?! wrong connections
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Isolate (sunglasses icon, lower left corner) beams and columns in the view that you're working with, apply bracing and restore visibility.
Connections to the wrong side !
Wed, Jan 29, 2014 at 7:55:09 AM
Brace that goes through a girt. Best way to break the brace?
Fri, May 10, 2013 at 11:29:35 AM
x brace frame
Wed, Dec 23, 2009 at 1:39:55 PM
after revit export to pdf the file is wrong scale
Sat, Nov 20, 2010 at 10:54:04 PM
What am I doing wrong?
Thu, Jul 19, 2018 at 2:26:56 PM
Page generation time: 0.1383
