Forums >> General Discussion >> Revit Project Management >> 3D views won't load! HELP!!
Wed, Aug 19, 2020 at 8:27:37 PM | 3D views won't load! HELP!!
NUTECH12
When trying to open a 3D view in the Revit 2019.2 model, it takes up to 6 minutes for the 3D view to load, then each time I adjust the clip range add an additional 6 minutes!  While processing this, the drawing session goes into Not Responding mode.
When using the Selection Box (BX) command, this does NOT provide a 3D view!  It just hangs the model, then the only way to close this would be to End Task and re-open the model.  Everything else seems to work just fine!
The other 3 ppl accessing this same model have no problems at all.  I am the only one that does!  We are each working remotely, via a remote website app called Connectwise.com
In this time for a remove and reinstall perhaps?  Hardware appears to be just fine.
Thu, Aug 20, 2020 at 5:50:52 AM | 3D views won't load! HELP!!
Your problem could be what elements are in the view.  Some of your problem may be elements that you don't see but still have to load.  Watch out for linked models and where they are located.  Also look for Linked CAD which could even be worse.
Sun, Aug 23, 2020 at 11:53:33 PM | 3D views won't load! HELP!!
NUTECH12
Thank you for your input.  Unfortunately, this only applies to my computer (remote) as the other 3 people on the team experience ZERO problems.
I have had a Revit re-install to 2019.2.2.  Nothing has resolved this very frustrating issue!  The other guys are able to open the same model from their respective homes with ease, opening 3D views without a prob!
#arghhhh
Sun, Aug 23, 2020 at 11:54:17 PM | 3D views won't load! HELP!!
NUTECH12
BTW, the linked models (ACAD 3D) were unloaded from the model
Wed, Aug 26, 2020 at 10:15:30 AM | 3D views won't load! HELP!!
NUTECH12
Hi there, would any one know if I can contact Autodesk support and speak to someone there without having a service agreement?
Family Won't Load
Mon, Apr 11, 2011 at 6:34:13 PM
Families won't load?
Tue, Sep 2, 2008 at 1:17:06 PM
2011 revit arch won't load families out of the imperial library
Mon, May 9, 2011 at 9:22:28 AM
'Door' Won't Load into Project
Tue, Sep 28, 2010 at 7:11:37 PM
Family Won't Load
Tue, Nov 28, 2017 at 8:50:38 AM
Page generation time: 1.2354
