Forums >> Revit Building >> Technical Support >> dimension tool for mass- non orthogonal faces
Thu, Jul 30, 2020 at 3:40:05 PM | dimension tool for mass- non orthogonal faces
mihaela
Hello,
1st problem- beginner level
I'm sorry if i skipped some beginer's lessons but i cannot dimension this mass witout perpendicular helping lines on every non ortho line
see the img attached, i've tried with walls, sometimes works, sometimes not. but i have a site plan with long alleys and life is short .
2nd.... how can I add the TYPE parameter to a mass- generic model or model in place- wall. floor or wthatever (not made inside a family), i need that parameter for schedules. I can add a new made by me parameter but for a bench lets say i dont want to fill the other 20more objects that parameter
thank you very much
Fri, Jul 31, 2020 at 5:49:20 AM | dimension tool for mass- non orthogonal faces
Revit dimensions are very precise.  If two objects are NOT parallel, you can not dimension between them.  Often, that is a problem with people that start with visually created mass objects.
For the dimension in question, I see the dimensions on the other side worked.  Why?  Learn how too dimension and how to use snaps.  Read this and it's references: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-Customize/files/GUID-A3947840-1F30-41D7-AF75-B61687952A07-htm.html
Fri, Jul 31, 2020 at 7:02:07 AM | dimension tool for mass- non orthogonal faces
mihaela
They didnt work, i created those helping lines, every dimension must have a perpendicular line on the one i want to measure, as much as I try I cannot snap on both points and have an aligned dimension, i must have a line and a point- at least i dont have to create 2 lines.
is something that i miss with snaps? can you snap on both points of the ends of a line and get a proper dimension?
thanks
Edited on: Fri, Jul 31, 2020 at 7:03:08 AM
Fri, Jul 31, 2020 at 8:14:08 AM | dimension tool for mass- non orthogonal faces
You can snap to both points and the dimension will be aligned.  Read how to use your snaps!
Fri, Jul 31, 2020 at 9:14:30 AM | dimension tool for mass- non orthogonal faces
mihaela
Thank you!
Now I know how to use snaps! Problem solved
(7tabs to get the point thou)
Fri, Jul 31, 2020 at 4:40:36 PM | dimension tool for mass- non orthogonal faces
You should read more of the knowledge item I posted and you would see how to use keyboard shortcuts.
Offset face of Mass = possible?
Tue, Jan 21, 2014 at 2:06:18 PM
best way to align a curtain system across many faces of a mass?
Wed, Sep 5, 2012 at 8:33:07 AM
Mass? instead of creating "floor area faces" can on create "section area faces"
Tue, Apr 25, 2006 at 1:56:40 PM
mass roof
Fri, Sep 12, 2008 at 6:34:30 AM
Roof by Face on curved mass surface issue
Mon, Oct 5, 2015 at 12:39:58 AM
Page generation time: 2.9898
