Forums >> Revit Building >> Technical Support >> Revit 2019 Physical Asset for Compressed fibre cement sheet
Thu, Jul 23, 2020 at 12:44:16 AM | Revit 2019 Physical Asset for Compressed fibre cement sheet
PsymonMKII
PsymonMKII Avatar
Anyone know what the physical asset equivalent would be for compressed fibre cement sheet as used in cladding - can't seem to see anything.
Trying to set up accurate thermal models.
CAD Manager
Using Revit since 2006 with a ten Year Break. Last version was 2009
Revit 2019 - 2021
Thu, Jul 23, 2020 at 7:43:54 AM | Revit 2019 Physical Asset for Compressed fibre cement sheet
Maybe this will help:
https://www.americanfibercement.com/bim-library/
Mon, Jul 27, 2020 at 6:57:30 PM | Revit 2019 Physical Asset for Compressed fibre cement sheet
PsymonMKII
PsymonMKII Avatar
Thanks. I am in Australia and was wonderig if there was a built in physical attribute rather than entering my own information and if I just can't find it because I don't know waht the Yanks call it.
CAD Manager
Revit 2019 - 2021
converting revit sheet to image
Sat, Mar 23, 2019 at 10:44:30 AM
This asset is shared with 13 other materials... and I don't like it.
Fri, Oct 18, 2019 at 8:47:38 AM
revit 2019 and revit 2024 same pc
Tue, Sep 19, 2023 at 7:54:31 AM
Cement Fiber Board Panels
Tue, Jan 9, 2018 at 2:20:08 PM
building a physical model from a revit file
Wed, May 9, 2007 at 9:31:57 PM
Page generation time: 1.4634
