Forums >> Revit Building >> Technical Support >> How do you cut a concrete structure such as walls and slab via topography?
Sun, Jul 19, 2020 at 9:27:15 PM | How do you cut a concrete structure such as walls and slab via topography?
albertiglesia
albertiglesia Avatar
I have a dam project and its structure concrete was made from "Model in-place" because the structure is irregular in shape, and it needs its base to follow the topographic surface, how can I do that?
Thank you in advance
"Pleasure in the job puts perfection in the work"
 - Aristotle
Mon, Jul 20, 2020 at 6:49:07 AM | How do you cut a concrete structure such as walls and slab via topography?
There has never been a concrete dam built that followed the topographical surface.  The bottom of the structure has to be soketed into the ground far enough to resist the shear load.  Your model should do the same thing.
slab thickening below hardcore
Wed, Jan 12, 2011 at 5:26:21 AM
Wall as slab support
Sun, Dec 20, 2009 at 3:31:23 PM
Cut Planes for CMU Bearing Wall Systems
Thu, Jun 4, 2009 at 6:08:28 PM
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:00 AM
Revit Architecture / Revit Structure Coordination Issues
Fri, May 7, 2010 at 10:19:04 AM
Page generation time: 4.4591
