Forums >> Revit Building >> Technical Support >> Skylight Room Name Schedules
Tue, Jul 14, 2020 at 12:30:48 PM | Skylight Room Name Schedules
lpluger21
Is it still not possible to get the skylight room name to show up nativly in the window schedule? Does anyone have a solution for this?
Wed, Jul 15, 2020 at 7:10:57 AM | Skylight Room Name Schedules
There may be a simple solution for this called room awareness.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-Model/files/GUID-D3AFF8AC-0175-4D89-B3F4-EEDCD128616C-htm.html
Wed, Jul 15, 2020 at 4:25:12 PM | Skylight Room Name Schedules
lpluger21
That is awesome!
I was able to adjust the family to get to show up in the location field of my window schedule but for some reason it won't stay in the schedule. Any idea? See the video of what I'm talking about.
Wed, Jul 15, 2020 at 4:30:25 PM | Skylight Room Name Schedules
lpluger21
Apologies for the double post response. Here's a video showing the issue The direct upload didn't work so here's an external link to the upload
https://gofile.io/d/kvRSVR
Edited on: Wed, Jul 15, 2020 at 4:36:22 PM
Thu, Jul 16, 2020 at 7:16:55 AM | Skylight Room Name Schedules
I looked at the video but that is NOT a Revit schedule.  It looks like a spread sheet.
Thu, Jul 16, 2020 at 9:53:50 AM | Skylight Room Name Schedules
lpluger21
I promise it is a revit schedule. See image.
Thu, Jul 16, 2020 at 4:16:45 PM | Skylight Room Name Schedules
I'm lost....
Why would you be filling in data that Revit would be supplying automatically?
I assume that the SYM column is your window - correct?  It's location should data field normally is automatic - why would you make it otherwise?
Thu, Jul 16, 2020 at 4:40:07 PM | Skylight Room Name Schedules
lpluger21
Correct the SYM column is the window/ skylight.
The issue is the Location column.
Correct Revit should be filling this in automatically/ providing you with 2 options (To room and From Room).
You gave me a link to be able to modify the room awareness so I could get the skylight to produce a room name. Which worked. (Prviously I just had 2 blank options.)
It now displays a blank field (which is the space above the roof which isn't a room at all) and Linda's office (the room where the skylight is located).
The issue is when I select Linda's office as the location i want to use it selects it and then clears the field and it's blank again (like in the video).
Does this clarify?
Fri, Jul 17, 2020 at 7:06:34 AM | Skylight Room Name Schedules
Do I see a skylight in the room to the left and does that one report correctly?  If so then you have something else wrong.  Look again at where your reporting point is in the family.  It does not need to be within the family limits, I would make it be farther away than the thickness of your roof.
Learn to pay attention when you place items like doors and windows.  Before the room aware fuction was added, we had to pay attention to how we placed the opening to get the correct reporting.  I did that all the time but many users could not figure it out.
Fri, Jul 17, 2020 at 3:13:39 PM | Skylight Room Name Schedules
lpluger21
Yes, there is a skylight in the next room but all of my skylight behave the same way.
See the family showing the calculation points.
Sat, Jul 18, 2020 at 7:28:08 AM | Skylight Room Name Schedules
Note this image found on this website: https://www.revitforum.org/showthread.php/19498-Do-U-Revit-To-From-Room-Door-Parameters
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
Skylight shaft
Tue, Sep 2, 2014 at 4:03:45 PM
Room schedules
Thu, Feb 7, 2013 at 4:44:14 PM
Large number of schedules
Mon, Jun 20, 2011 at 12:56:18 PM
Room Numbers in Schedules
Wed, Jan 25, 2006 at 3:26:56 PM
Page generation time: 0.1804
